Browse Forums Paving & Concreting 1 May 24, 2011 10:16 pm We are looking at building concrete for Alfresco flooring and a bit outside the alfresco area. It is overalol around 44 sq. m. I then plan to lay outdoor tiles on these. Question is for such a concrete slab (10 cm), would any piering be required? If not, doesnt it pose risk in case of ground/soil movement. ------------------------------------------------------- http://homeinkalina.blogspot.com Enjoying our new Concerto with Allworth Homes in Kalina, The Ponds Handover - 28/06/2011 Re: Piering require for concrete patio 3May 25, 2011 6:42 am If the House foundations around your alfresco area is on piers or is all filled ground piers may be needed but otherwise you shouldn't need them The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16104 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7744 If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5496 |
