Browse Forums Paving & Concreting 1 May 24, 2011 6:20 pm We are installing a Jetmaster open fire place 850 model. We are surrounding it with a wall unit and installing a 400mm high caesterstone topped bench for use as hearth, shelving and seat. This will span the full length of the wall. Flooring is timber floorboards. We have a maximum of 650mm depth we can go to either side of the fireplace (meets the bifold doors on one side). Unfortunately, given the depth of the fireplace (approx 500mm), this does not meet the minimum requirements of the forward projection of the hearth which must be 300mm directly in front and 200mm either side of the fireplace. I suppose our first option is to jut the hearth out around the fireplace, but I also wondered if perhaps anyone had any other options - perhaps just putting a slab of ceaserstone or similar on the floor in front of the fireplace? Any one had this issue? Re: Jetmaster open fireplace hearth requirements 3May 24, 2011 8:08 pm I love the look of the concrete ones too Aiah, but don't want to introduce another element into this open plan space (will be using the same surface in our kitchen and island bench). I'm pretty sure caeserstone is OK with the heat... Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4931 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13724 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11584 |
