Browse Forums Paving & Concreting Re: Driveway & Concrete footing 2Apr 03, 2011 11:14 am What does the engineering detail say? IMHO only yes you should have plastic under concrete. BTW if anyone mentions mesh NOT be attached for saw cuts tell them they are wrong! Saw cuts don't go full depth and probably less than 35mm. Where you are coming from is where you are going to... Re: Driveway & Concrete footing 4Apr 03, 2011 11:32 am Say what????????????? So I think the mesh is the least of your problems... but you must have a slab & footing 'detail' or how do you know the very beginning of your build is correct? Or are we just talking about a driveway? If so F(N)72 is fine unless you are going to be driving trucks with weight on them along the drive. Where you are coming from is where you are going to... Re: Driveway & Concrete footing 5Apr 03, 2011 11:41 am BTW mesh will NOT help or stop the concrete from cracking, it will hold it together though should/when it cracks. Curing concrete in the best possible way will be the only thing to reduce cracking. Where you are coming from is where you are going to... Re: Driveway & Concrete footing 7Apr 03, 2011 12:01 pm Well I don't want to sound sad but it is very important to know it will be functioning for a looong time to come. That is why engineers are asked to comment, I can follow a plan but draw one with all the correct info and I am out of my depth. For a footing though it is unlikely plastic will make a diff' however refer to my previous post re footing & slab detail. It will be there somewhere?? or should be! Sorry it is my one day off so my brain is in neutral. Where you are coming from is where you are going to... Re: Driveway & Concrete footing 8Apr 03, 2011 3:32 pm Onc, this is the day off?? Anyway, onc_artisan if anyone mentions mesh NOT be attached for saw cuts tell them they are wrong! BTW, it's the norm in Sydney - if you ask for plastic under a driveway, they'll look at you as if you've just arrived from Jupiter! Or, they'll write you a quote you cannot not refuse My signature is distracting people from my wise posts ... Re: Driveway & Concrete footing 9Apr 03, 2011 4:13 pm Yeh well I've been fishing... albeit in the back yard as there is a surf contest here ATM... so Trout will have to do. Never mind. Hey I don't make the rules I just do as we figure is best ok... Anyone can do what they please. BTW attached as in Mesh tied together, or guess what, nothing will hold it together. Where you are coming from is where you are going to... Re: Driveway & Concrete footing 11Apr 03, 2011 4:41 pm Where you are coming from is where you are going to... yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7331 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10256 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3328 |
