Browse Forums Paving & Concreting Re: Driveway & Concrete footing 2Apr 03, 2011 11:14 am Where you are coming from is where you are going to... Re: Driveway & Concrete footing 4Apr 03, 2011 11:32 am Where you are coming from is where you are going to... Re: Driveway & Concrete footing 5Apr 03, 2011 11:41 am Where you are coming from is where you are going to... Re: Driveway & Concrete footing 7Apr 03, 2011 12:01 pm Where you are coming from is where you are going to... Re: Driveway & Concrete footing 9Apr 03, 2011 4:13 pm Where you are coming from is where you are going to... Re: Driveway & Concrete footing 11Apr 03, 2011 4:41 pm Where you are coming from is where you are going to... yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7250 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10171 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3293 |
