Browse Forums Paving & Concreting 1 Mar 28, 2011 12:52 pm I have a storage room that is shared with 3 other units. It's about 9-10Sqm. At present the sandy soil base is cover with sheets of plastic to stop the dust and sand getting on our items. What is the best and cheapest way to have the ground covered in pavers or concrete. It does not have to be fancy, it's only a storage room. If pavers where is the cheapest place to purchase them. I thinking of 400mx 400mm concrete pavers. Any assistance will be much appreciated. Thanks David DIY, Home Maintenance & Repair to do it properly you need to dig out the garden and waterproof the outside of the wall. There are some products you can put on the face of the bricks but the water is… 2 4624 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12399 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
