Browse Forums Paving & Concreting 1 Mar 18, 2011 1:42 pm Hi, Does anybody have any good ideas for paving patterns? We are using Castlestone pavers (http//www.castlestone.net.au/paver.html) in the limestone and charcoal, 400x400. The idea is to have the charcoal as the main colour for the driveway and front and then reversed in the back anround the pool. Cheers Re: Paving Ideas 2Mar 18, 2011 7:08 pm Depends on the shape of the area too. If you are using 2 colours, typically you would use one as the border, eg. all around the edges of the dwy, and then the other colour to fill in, but that paver would be done diagonally. What texture did you go for? Slate, Beach or Reef? And why ? What thickness? I assume 60mm for the dwy?? My signature is distracting people from my wise posts ... Re: Paving Ideas 3Mar 22, 2011 10:17 am Standard driveway, 6m wide x 5m long, I had a few ideas but want to do something a little "different"! We went for the slate pattern, just liked the texture of it and thought it would create a nice effect. 60mm thickness on the dwy, 40 mm elsewhere. I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12385 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
