Browse Forums Paving & Concreting 1 Feb 28, 2011 10:16 pm first of all, not sure if this is the right section i should be putting this on , so apologies if it this is the wrong place for this post.. i am trying to put some drainage around the house to prevent water pooling when we get heavy rains. will dig a trench and use 90mm stormwater pipes. they will be to the side of the pathways (crushed rock w/ tuscan topping) so i don't think they will get heavy foot traffic.. question is how deep should they be? thanks.. Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog Re: stormwater drainage - how deep 2Mar 01, 2011 4:43 am 300mm cover to the pipe would be plenty. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: stormwater drainage - how deep 3Mar 01, 2011 8:55 am So around 500mm deep? 300mm cover + 90mm pipe + 100mm crushed rock? Re: stormwater drainage - how deep 4Mar 01, 2011 11:07 am 400 mm deep, Cover includes crushed rock The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: stormwater drainage - how deep 5Mar 01, 2011 12:28 pm is that crushed rock under or on top of the pipes? i was just planning to put the pipes on top of the clay soil and then cover it with crushed rock.. Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog Re: stormwater drainage - how deep 6Mar 01, 2011 12:40 pm I thought you need 100mm crushed rock under the pipe also? Re: stormwater drainage - how deep 7Mar 01, 2011 3:52 pm For a location like this where there is no big loads there is no real need for crushed rock/or sand under the pipe. Lay the pipe on the bottom of the trench and place sand alongside and over pipe. Best job is to water it in. The trench can then be backfilled with soil if its garden or crushed rock if its under the path. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4859 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7932 |
