Browse Forums Paving & Concreting Re: Covered weep holes :( 7Apr 11, 2011 11:15 pm . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Covered weep holes :( 8Apr 21, 2011 11:38 am This document has some pictures and a description of what can happen when your paving or garden bed is too high.. http://www.concrete.net.au/publications ... mpness.pdf Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Covered weep holes :( 9Jul 23, 2021 11:02 am We have the same issue now and it's my mistake for not doing my homework before we got the tiling done. But our walls with weepholes are undercover and the floor is sloping away. Am stressed thinking about it. We also plan to do a acrylic render later on .. will this help? it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7094 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5458 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11185 |
