Browse Forums Paving & Concreting 1 Feb 19, 2011 1:56 pm i got an alfresco area that is open on two sides. sometimes when it rains, the floor gets really wet and since it is levelled, water would stay there until it dries out or i brush it out. would this weaken the concrete/slab? also, i am planning to put decking to this area but i would not be able to brush out the water and it would need to dry out. any comments or suggestions to fix this problem? or is it even a problem? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog Re: wet concrete floor 2Feb 19, 2011 2:00 pm Can't see how the water is a problem to the concrete. As for the decking it depends on the fixing detail. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: wet concrete floor 4Feb 21, 2011 10:41 pm thanks all.. will not worry about it for now i guess.. Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3663 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16558 |
