Browse Forums Paving & Concreting 1 Feb 10, 2011 5:24 pm I've just had about 20-30 cubic metres of sandstone dug out at my place and now left with a nice area that needs to be paved.... Before I had the rock cut out I'd had a number of people come and have a look, but they got scared off by the rock.... anyway this one landscaper has been helpful all the way along.. he's actually come out about 3 times to give advice and now that the rock is gone he's going to be giving me a quote to do some paving but I'm a little worried about what his price is going to be... from the sounds of it, he doesn't get his hands dirty, he gets others to do the work, so I'm a little worried that he'll mark the price up a lot. The area is approximately 8 metres x 4 metres, I'll be getting probably 400mm square pavers, no fancy patterns. Will need some roadbase and sand I'm guessing to do it properly... So yeah just wondering roughly what would I expect to be paying just for the labour to lay pavers for this size? (not including the cost for the pavers). While I'm at it... how hard is it to build a garden bed along a fence... I'm going to be using the rocks from the excavation so its just the rough look... only about 30cm high. Not sure if I need to put a concrete base alll the way along, or just lay the rocks directly on the ground... Thanks Re: Approx cost to lay pavers 2Feb 11, 2011 5:12 pm entry level landscape company app. $75 sq mtr for labour. We start at $100-$120 sq mtr for labour, you get what you pay for in most cases but not all. The rock wall if it is dry stack as in no mortar joints then install a compacted crused rock base app. 250mm deep x the width of the wall stabilised with cement. Then just neatly stake the rocks ontop of each other with shaping using a scutch hammer and cold chisel. Install an aggregate drain behind wall. If you want mortar joints install on an app. 300-400mm deep footing x width of wall with 3f12 trench mesh top and bottom (double steel) and use a 4:1 ratio washed sand and white brick sand mortar mix with something like lanotek in it (from bunnings) Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 14386 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 11366 |
