Browse Forums Paving & Concreting 1 Jan 05, 2011 1:04 pm We've used sandstone tiles for our external walkway and have noticed brown stains on the tiles where the leaves have fell. The tiles were sealed shortly after they were laid 2 weeks ago. What can we use to clean the tiles? We get lots of leaves falling on those walkway! Re: Stain from leaves on sandstone paving 2Jan 05, 2011 6:45 pm SYD-YYZ We've used sandstone tiles for our external walkway and have noticed brown stains on the tiles where the leaves have fell. The tiles were sealed shortly after they were laid 2 weeks ago. What can we use to clean the tiles? We get lots of leaves falling on those walkway! Hey, Depending where you are, in Melbourne (and some other states) there is this amazing product called Cleaner 303 by Miteq Will remove those stains no problem. You may want to do it sooner rather than later to stop them penetrating to deeply into your sandstone. May also want to consider sealing them as well Miteq Re: Stain from leaves on sandstone paving 3Jan 06, 2011 9:50 am miteq SYD-YYZ We've used sandstone tiles for our external walkway and have noticed brown stains on the tiles where the leaves have fell. The tiles were sealed shortly after they were laid 2 weeks ago. What can we use to clean the tiles? We get lots of leaves falling on those walkway! Hey, Depending where you are, in Melbourne (and some other states) there is this amazing product called Cleaner 303 by Miteq Will remove those stains no problem. You may want to do it sooner rather than later to stop them penetrating to deeply into your sandstone. May also want to consider sealing them as well Miteq I am in Sydney and we have already sealed the sandstone already. Thanks. Re: Stain from leaves on sandstone paving 4Jan 07, 2011 1:37 am If you know a person with a chlorine pool ask for some sodium hypo ... use it 'straight'. Otherwise go and buy a 15 ltr sodium Hypo from a pool shop That will get ride of the stain Where you are coming from is where you are going to... Re: Stain from leaves on sandstone paving 5Jan 11, 2011 3:38 pm you can also use a 10:1 ratio bleach but dampen the surface first and only do small areas at a time. rinse thoroughly. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 9627 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 4599 The most definitive answer to your question James is this taken from the James Hardie Axon Cladding Installation Guide - i just happen to have it… 5 2050 |
