We just had liquid limestone poured, and the surface feels very rough on the foot.
Is it normal that liquid limestone has a rough surface?
Browse Forums Paving & Concreting Re: Liquid Limestone Finishing 2Dec 18, 2010 10:29 pm You had options prior to the placement.. so now i guess you have the average finish It is 'scored' and small pieces of aggregate 'pull up' to give a rough ish surface. It is possible to smooth it a bit... though it will wear a bit over time. Where you are coming from is where you are going to... Re: Liquid Limestone Finishing 3Dec 21, 2010 5:48 pm I did mine myself and used a brushed finish, I like it but my slabs have different "colours", ie a couple are pale white but a few are blotchy with yellowish patches that look like they have not completely dried but they have. Doesn't really worry me as it is a rustic landscape but I would prefer an even shade, is there anything I can do? Also, I did not seal slabs with anything, do I have to or can I go with unsealed? If I do seal what will be the effect / advantage. Thanks in avance, gurus Re: Liquid Limestone Finishing 4Dec 23, 2010 9:57 am I think it would have een preferable to have sealed it. Limestone is very porous and will pick up all the stains and discolour. Where you are coming from is where you are going to... Re: Liquid Limestone Finishing 6Dec 24, 2010 9:35 am Hi ya, not sure what your intention is or what the slab is for .... But a sealer will repel staining and dirt pick up. Where you are coming from is where you are going to... Re: Liquid Limestone Finishing 7Jan 11, 2011 6:26 pm Our LL finish also came out "rough". I was partly annoyned at the installer for not mentioning about the choice of smooth or rough finishing, but i had simply assumed it will have a smooth finish so didnt bother asking. 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6980 |
