Browse Forums Paving & Concreting 1 Dec 13, 2010 1:34 pm Hello, Can anyone suggest a good paving sealer for concrete pavers that gives them a wet loo without being slippery? Could it also be used on our red brick path? Thanks in advance. My renovation blog: http://landhousereno.blogspot.com.au/ Or like me on facebook: The little yellow house About to extend our Edwardian House in West Footscray, Melbourne D & N and 3 kids. Re: Recommend a good wet look paving sealer 2Dec 13, 2010 3:56 pm What your asking is something that goes hand in hand unfortunatley. Wet = slippery. (most of the time) We have a non slip option that has been tested to AS/NZ standards. I recommend doing a sample first to make sure you like the look and non-slip option. Also, depending on how your pavers are finsihed you may actually get away with a standard wet look if the paver is rough enough. One major thing to know is that a wet look is not breathable. So if there is moisture or salts under the pavers/substrate, there is apossibility that it can rise to the surface and pop the sealer off. You must make sure that the substrate is dry and free of mositure to apply a surface sealer. Hope this heaps, if your in Melbourne, look me up or pm me. Happy to help futher if needs be. All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3665 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12411 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 |
