Browse Forums Paving & Concreting 1 Nov 06, 2010 8:56 pm Hi Our slab has been laided and the builders have started the frame work. Everything good so far except in the laundry the slab wet area cut out and the frame are not parallel leaving a gap of 10cm on one end. Does anyone know if this is very common ?? We are not sure if it is going to be a big problem later on? Or if the tiler can fix it ? Anyway any comments would be helpful. Thanks 2 6108 Thank you every one for you input , after a lot of research and reading so many blogs decided to go with timber and brick as its the most safest option 7 3796 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28157 |
