Pool Render
Would appreciate any advice.
I have removed my old waterline tiles and glue patches. Water line area is due to get rendered, prior to tiler placing tiles. Tiler requested rendered surface so that the new mosaic tiles can be evenly placed.
The renderer has said he will just use a regular sand and cement mix.
I am concerned that he should use a dedicated product that works better underwater.
Does such a render exist or does he need to add an additive to his standard above water mix?
Or will his normal render mix do, as it will be covered with tiles and grout anyway.
My pool is indoor in Melbourne, so climate is not as harsh as some.
Thanks for help!
12
Hi Alex, Thanks for the reply again. I had a chat with the builder, he said he will use primer, then hydrotec which comes with colour and sealer as well. A Renderer I…
23/08/2023
I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps…
4/10/2023
5
Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,…
