Browse Forums Paving & Concreting 1 Oct 21, 2010 6:54 pm I am thinking of DIY concreting/paving the area (footpath) around the house but currently, the ground (soil fill ??) is too low (around the same height as the slab, i can just see the slab on the side). Weep holes are 2 bricks above the slab and I want the footpath to be 1 brick above than the slab (so it is 1 brick below the weep holes). What filling do I need to use so that i don't have to use too much concrete? Do I just use soil filling like this one http://www.allgreen.com.au/product_info.php?cPath=1_3&products_id=50 or crushed rock like this one http://www.allgreen.com.au/product_info ... ucts_id=55 Thanks. Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20176 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17353 |
