Hi few questions for those with polished concrete (and hopefully Onc too):-
1. Are they able to be used in wet areas?
2. And if so - how slippery are they?
We are finalizing our pool cabana plans which will be on a concrete slab.
Browse Forums Paving & Concreting 1 Oct 20, 2010 1:57 pm Hi few questions for those with polished concrete (and hopefully Onc too):- 1. Are they able to be used in wet areas? 2. And if so - how slippery are they? We are finalizing our pool cabana plans which will be on a concrete slab. Some things are worth waiting for. Polished concrete question? 2Oct 20, 2010 1:59 pm Oops hit send too quick. Anyhoo the cabana will have a changeroom down one end then open the balance. So we are trying to work out what to do with the floor that will flow between the two areas (and into the adjoining pool area). Any advice is appreciated. Some things are worth waiting for. Re: Polished concrete question? 4Oct 20, 2010 5:12 pm Less slippery that a LOT of tiles Where you are coming from is where you are going to... You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 |
