Browse Forums Paving & Concreting 1 Oct 18, 2010 2:21 pm I have used ag pipe in place of soakwells for drainage from downpipes and am getting liquid limestone poured in a few weeks time. Some of the ag pipe runs underneath where the liquid limeston will be. Is this ok, or is it likely to lead to cracking? Should I remove the ag pipe and replace with soakwells, or am I just being paranoid? Thanks Re: Ag pipe under liquid limestone 2Oct 21, 2010 12:30 pm Anyone? What im getting at is that the agpipe will wet the soil under the liquid limestone, will this campact/wash away soil and effect the liquid limestone? Re: Ag pipe under liquid limestone 4Oct 21, 2010 10:31 pm Yep it is socked, probably 300mm deep at the moment (hopefully this doesnt change too much when it is leveled). OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19950 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7297 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 |
