Browse Forums Paving & Concreting 1 Oct 18, 2010 2:21 pm I have used ag pipe in place of soakwells for drainage from downpipes and am getting liquid limestone poured in a few weeks time. Some of the ag pipe runs underneath where the liquid limeston will be. Is this ok, or is it likely to lead to cracking? Should I remove the ag pipe and replace with soakwells, or am I just being paranoid? Thanks Re: Ag pipe under liquid limestone 2Oct 21, 2010 12:30 pm Anyone? What im getting at is that the agpipe will wet the soil under the liquid limestone, will this campact/wash away soil and effect the liquid limestone? Re: Ag pipe under liquid limestone 4Oct 21, 2010 10:31 pm Yep it is socked, probably 300mm deep at the moment (hopefully this doesnt change too much when it is leveled). yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7340 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4894 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3257 |
