Browse Forums Paving & Concreting Re: Base for concreting on 2Nov 19, 2007 8:32 pm "Cracker dust" or "crusher dust" is the go around my area - as advised by all the concreters & bobcat drivers I've used for various work over the years.
This "cracker dust" is actually recycled concrete from a local recycling plant. It goes down easy, can be raked, then wacker-packed, and if you wet it down, it goes crusty & hard, providing a great base. I put 450mm of it down in one area, under a 5 x 8m slab (dug out heaps of sloppy, wet clay) and packed it well between truckloads, and in 8 years that slab never cracked. It's also providing a 150mm (and deeper in some spots) base for my old driveway (around 120sq m) and it's only ever copped 1 hairline crack across it, which started at a 270 degree brick corner - an area prone to break. Re: Base for concreting on 3Nov 20, 2007 12:06 am we use yellow brickies sand here. my mate has a concreting company and they use it too. we use it for paving, house slabs, footpaths etc It is leveled and compacted before the concrete is poured.
we use crushed and compacted limestone for road base as well. typical sandgropers using sand ![]() Re: Base for concreting on 4Nov 20, 2007 12:09 am I read a bit on that cracker dust nut. it is supposed to be great stuff. It also makes a better use of building waste (even though a shinto load of energy is used to re-manufacture it ![]() It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 1575 ![]() We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 2499 1 2514 ![]() |
