Browse Forums Paving & Concreting 1 Oct 05, 2010 4:11 pm Hi My stormwater system was completely blocked and I had to dig up my concrete driveway and then dig about 10 metres of trench (roughly 700mm deep and 600mm wide) to access the damaged storm water pipes. Having done so, I replaced all the old 90mm pipes with 100mm pipes. The ground has a high clay content but no rocks of note. I have now decided to replace the concrete driveway with clay pavers (230 x 115 x 50). As I understand it though, I need to be very careful about how I fill the open trench before paving. My plan is to cover the new 100mm SW pipes with 100mm of river sand (200mm in total), compact it, and then progressively fill the remaining 600 - 700 mm with road base, compacting (by hand) every 100mm. Is that the way to go or is there a better way? I definitely do not want to end up with a sunken driveway and I want to get it right. Thanks John Re: Preparing to pave a driveway 3Oct 07, 2010 6:06 am Your on the right track, did you dig the whole drive or where the trench is ? Landscape Design & Construction http://cherub.squarespace.com/ Re: Preparing to pave a driveway 5Oct 07, 2010 3:54 pm Would drill a few holes in slab and insert some steel pegs and re concrete to match existing, then pave Landscape Design & Construction http://cherub.squarespace.com/ Re: Preparing to pave a driveway 7Oct 07, 2010 7:03 pm Just back fill in lifts as above, would rake in cement with road base on last lift and compact and hose in. Landscape Design & Construction http://cherub.squarespace.com/ I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3051 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 |
