Browse Forums Paving & Concreting 1 Sep 22, 2010 9:44 am We're just starting to build and we have had the builder asking us a few questions about the slab height. It was drawn on the plans at 410mm as that was what we were told was standard for a waffle pod slab (by the engineer). The builder rang us a few days ago and asked if there was a reason it was 410mm and not 370mm as with the lower height there didnt need to be a step up from the garage into the house. He wanted to know if we we're happy for it to be done at 370mm. Now we don't really care about the height, council's minimum slab height here is 100mm so there is no issue wih council but I just want to know what is normal for a waffle pod slab on HD soil? I have tried ot find it on the internet but cant find anything to help me out so if there is someone on here that can help that would be great. So I'm after some info so we can make the right decision. Thanx in advance Re: Waffle Pod Slab Height? 2Sep 22, 2010 10:23 am That is a bit confusing Slab height is normally the height the slab sits from a given datum. ( an RL point ) a slab thickness is the thickness of the slab but doesn't refer to the height in any way. Contour lines on the site plan will indicate the road height, slab height and other features on the site. They look like this 10.0 for example only. ...there will be a series of numbers indicating relative heights. The slab will have a 0 point and the rebate will/may have -1c (minus 1 course or -2c) referring to the first brick course and the relative slab height. 410 and 370 may be the thickness of the waffles and slab thickness combined but the builder should not be asking you any of this. 40 mm is not a brick height a brick is 86 mm and is the normal stepdown( actually the minimum stepdown) All to confusing don't you think? Onc Where you are coming from is where you are going to... Re: Waffle Pod Slab Height? 3Sep 22, 2010 10:42 am Totally confusing. Slab height from ground on the plans from the moron who drew them up (we dont have much faith in her) in the sectional plan is specified as 400mm, which makes even less sense to me now. Someone told me that for a waffle pod slab the height from the ground was 410mm. On the engineers plan, I can't find any mention of height about ground but in the slab notes it says the "slab is to be 85mm thick ribbed raft slab etc". Then when I look at the typical details drawing of the slab cross sections it looks to me like the minimum from the ground to top of slab is 385mm (with 85mm being the slab thickness). With the garage step details they have a step down from the main slab to the garage of 172mm? We don't have asite plan with contour lines but the area is pretty well flat, does that make anymore sense? If it confused you no wonder it has confused us. Basically the builder wanted to know if there was a reason for the slab being 410mm or if he could do it at 370mm. Re: Waffle Pod Slab Height? 4Sep 22, 2010 10:58 am 172mm is 86mm * 2. Two brick courses? It still doesn't make sense why 40mm would mean there would be no step down. Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Waffle Pod Slab Height? 5Sep 22, 2010 11:41 am I would be telling the builder to speak to the engineer who designed the slab, they design them in a particular way to suit the site for a reason, you may even like to talk to the engineer yourself just to make sure it is ok for the site and to put yourself at ease. Most plans have the engineer name listed on them. I have spoken to ours and they were very helpful and explained our queries. Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Waffle Pod Slab Height? 6Sep 22, 2010 11:43 am Hmmm just as I thought a 2 c rebate to further confuse things. Where you are coming from is where you are going to... Re: Waffle Pod Slab Height? 7Sep 22, 2010 2:56 pm Well I emailed the engineer (we had arranged him in the first place so I had all his details) he said the 410mm is the standard for G town, we are in a village outside the town so different council and he had no issue with the 370mm. The only thing he said was to check with council that it was ok - I know that the council min here is 100mm. So I guess since there is no issue from an engineering point of view then really having the slab height at 370 rather than 410 is going to save us some money in concreting and the house will be a little lower. Weird I'm still confused. Re: Waffle Pod Slab Height? 8Sep 22, 2010 6:46 pm Waffle pods come in different heights, ours were 225mm plus 85mm concrete cover gives 310mm. Height of waffle pod is usually determined by soil type as this determined the height/depth of the beams between and around the pods that create strenght level required in the slab. Your drafter may not of sourced accruate information on the slab. Check http://www.slabworks.com.au/Waffle_Pods.php Brick setdowns are in the edge beam of the slab and have no bearing on the thickness of the waffle pods. In Victoris you are not permitted to have the garage at the same level as the house slab and the difference in height is usually 1 brick down. This was introduced to limit flodding from garages into houses. Re: Waffle Pod Slab Height? 9Sep 23, 2010 11:51 am We have just put in a waffle pod slab for the house on "P" Class soil (the worst kind!) I was told that because of our of ground classification we required a bigger Waffle Pod than normal The finished slab height was 410mm consisting of Base 150mm FCR (Fine Crushed Rock) 50mm Sand Slab 300mm Waffle Pod 110mm Concrete on top our Garage slab height was 335mm Base 150mm FCR (Fine Crushed Rock) 50mm Sand Slab 225mm Waffle Pod 110mm Concrete on top I hope that helps Re: Waffle Pod Slab Height? 10Sep 24, 2010 6:51 pm a 150mm footing for brick work and then 257mm (3 courses) to top of slab. 407mm its purely to work courses from floor height to windows and eves. and can be worked easily around if its put in at 385 instead. a 22mm x 300mm footing would be dug around the edge board. I dont understand where your getting the 370mm measurement. 385, or 400mm would be minimums for 300mm waffle pods. Re: Waffle Pod Slab Height? 11Mar 30, 2015 2:45 pm Hi There, I am building with Simonds, and Intrax do the engineering designs for slab I asked to raise finished floor level of porch 150mm as neighbour potrch They came up with a design of putting double waffle pod, instead of adding thickness to concrete so the concrete is now 85mm, the total slab thickness is 535mm means that void form height is 450mm I don't know if anyone heard about double waffle pod, because I didn't find anything on web The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9991 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7844 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9741 |
