Browse Forums Paving & Concreting 1 Aug 18, 2010 10:05 pm Does anyone know how to pave the driveway if it is falling at a little angle? Any DIY videos or tips available related to this topic? Re: DIY Q: block paving driveway 2Aug 19, 2010 10:07 pm Firstly where do you live ? If in WA might be able to help Follow Feggle viewtopic.php?f=31&t=34992 Follow lilfeggle viewtopic.php?f=31&t=37149 Asbestosis Sux! Don't breath in Asbestos Re: DIY Q: block paving driveway 4Aug 28, 2010 12:17 pm oh no i can't help you - I'm in WA Follow Feggle viewtopic.php?f=31&t=34992 Follow lilfeggle viewtopic.php?f=31&t=37149 Asbestosis Sux! Don't breath in Asbestos Re: DIY Q: block paving driveway 5Sep 06, 2010 9:47 am dreamhouse, paving a driveway with little fall is what you want to ensure a good drainage. There are heaps of guides out there to help which include Boral's website and much more. First of all good good drainage you need a greater than 25mm incline every 1000mm, lay the sand as per normal and when you get to paving start from the bottom up, use 50mm or greater pavers (driveway use) and use a heavy base underneath the sand like B grade crush rock or a layer of concrete. I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12490 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5763 |
