Browse Forums Paving & Concreting 1 Aug 15, 2010 7:04 pm I'm building in Melb West. The site survey recommends paving around the house to regulate moiature. The plans show the storm water running under the garage as well as all the normal stuff (water pipes, sink, shower, toilet) running under, or where the paving will go. In addition we have found an old crush rock filled storm water pit located under the slab where our Alfresco sits. Is this a problem??????????????????? Not sure if this is the right place to ask. But if all these pipes run under the slab or the concrete paving I intend to put in, how do you repair a pipe if it breaks??????????????? Is the pit a potential problem?????????????? As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7816 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6846 |
