Browse Forums Paving & Concreting 1 Jul 15, 2010 10:10 am Hi all, interested in the experts opinions as whether an 80mm liquid limestone slab arrangement could be poured around a swimming pool without removing the existing brick paving. The levels work out well as there is a 40mm fiberglass lip on the pool which I want to cover with a 40mm/50mm coping paver, leaving 80-90mm thick back which I want to pave up to with liquid limestone slabs over the existing brick paving. The existing brick paving is on a yellow sand base with mortar bed on top grouted with beach sand by the looks. (which the ants mine out regularly) There are a couple of spots where the paving has sunk due to water overflows (mainly around skimmer box / steps) which I would backfill and compact, possibly with concrete. The entire area would be edge contained by planter boxes/retaining walls/buried limestone block edging so no chance of the brickwork blowing out to any side. Will install plenty joints in the slabs. What do you think - too slack ? A grano worker mate reckons it would work but am after second opinions. Also, has anyone got any feedback on liquid limestone pool surrounds after a few years, does it deteriorate / start to look crappy ? cheers Re: Liquid limestone over brick paving - too slack ? 2Jul 16, 2010 1:10 am UP the cement content and use a laser level to check your minimum thinkness and make it 85mm. Where you are coming from is where you are going to... Re: Liquid limestone over brick paving - too slack ? 3Jul 16, 2010 9:27 am So you think I could get away with it then, Onc? I have been using a 5:1 mix of cement/limestone for my paths, go to a 4:1 then, Onc? And while I have got you there, should I put in a foam expansion joint between pool coping pavers & slabs, and if so what is the the best sealant to use over this that can colour match LL ? cheers Re: Liquid limestone over brick paving - too slack ? 4Jul 16, 2010 9:39 am Should be about right. Sika and a few others have sandstone coloured jointing. Where you are coming from is where you are going to... As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 7315 I recently hit a snag with my new build with Metricon. On the block I purchased there is an old covenant when the land was subdivided in 1971 that "the exterior walls of… 0 1520 |
