Browse Forums Paving & Concreting 1 Jul 04, 2010 1:39 pm Hi i'm new here and really have no idea about concreting and I'm getting quite confused from some of the posts i read! We want to get our driveway concreted, which then flows into the back yard. We also need a retaining wall too and there will be some excavation to do the driveay and we want new gates into the back yard. What should be be asking for? i read a post here on how to know if your concretor is a good one, that users lots of "tems" that i don't understand - sl62, sl72 use of chairs, slump etc so can someone please explain? Obviously when i get quotes i want to be able to compare apples with apples, not just cost. Also does it make any difference to the process if most of the contrete is on a sloap? And if we need retaining walls and gates do these need to be done before the contceting, after, during (gates)? Sorry for so many questions but its looking to be a quite expensive job , and do normal concreters do stairs too? thanks for any help! Re: Driveway - concreting 2Jul 04, 2010 3:52 pm The 62 - 72 refers to the 'mesh' size, Slump is the amount of water to give concrete more or less slump... Slump is the amount of 'flow' concrete has, with a certain amount of water added. Concretors (Grano's .. called this because we work with granite, mostly) can do most stairs, if they are any good, they will have to make some 'forms' for the concrete. Where you are coming from is where you are going to... Re: Driveway - concreting 4Jul 10, 2010 5:06 pm Get a quote - The materials 'should' be listed If not, ask and apply them to the quote and sign off on it That is : Concrete mix design ( 20, 25, 32 mpa concrete) Mesh, plastic & cure method. Where you are coming from is where you are going to... We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4491 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8376 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9228 |
