Browse Forums Paving & Concreting Re: How do I know if the concreter will do a good job?? 9Jun 29, 2010 5:43 pm Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: How do I know if the concreter will do a good job?? 10Jun 29, 2010 9:21 pm Where you are coming from is where you are going to... Re: How do I know if the concreter will do a good job?? 13Jun 30, 2010 4:01 pm Where you are coming from is where you are going to... Re: How do I know if the concreter will do a good job?? 15Jun 30, 2010 4:15 pm Where you are coming from is where you are going to... Re: How do I know if the concreter will do a good job?? 17Jun 30, 2010 6:07 pm Dukekamaya 72 is only $10/sheet more than 62 - about $72 / sheet add up the sqm of the concreteing you need done and divide it by 12.8 and round it up. I wouldnt even consider sl62 for a driveway. Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 11443 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7170 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10530 |
