Browse Forums Paving & Concreting Re: Paving vs concrete. Which one is better? 2Jun 26, 2010 10:28 am Paving is partially porous but it can also destabilise if not laid well. Loose pavers can be common with buckling. I still like the look of pavers though, so you can get them laid on a bed of concrete, which defeats the porous nature. Concrete can have such a wide variety of finishes so it can be so much more versatile but I hate the look of concrete when it's cracked. Re: Paving vs concrete. Which one is better? 3Jun 26, 2010 10:33 am There are many threads with the same question... ...from my biased position concrete is superior. .... I would go for exposed aggregate. For longevity, look, durability. Where you are coming from is where you are going to... Re: Paving vs concrete. Which one is better? 4Jun 26, 2010 8:15 pm We're planning on exposed aggregate concrete for this current house. I like the look of it, it doesn't move, no weeds or ants to deal with. Plus someone else will do the installation! With pavers we always DIY and after doing 60m2 of it at our old house I'd rather not do it again. Re: Paving vs concrete. Which one is better? 5Jun 26, 2010 8:57 pm In our old house we had 400m of paving half on concrete (150mm + renforcing for the car port and the bit to the shed) and the rest on "road base with cement" well.... /begin rant Never again. 200 meters that crack buckled and drop and moved depending on the season 5cm gaps would appear and disappear. And 200 meters that looked exactly the same as the day it was laid. It looked way better that plain or textured or concrete but was awful on road base. Next time, well this time we are conceting every thing and then tiling the lot. /end rant Hope this helps brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7650 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1780 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5780 |
