Browse Forums Paving & Concreting Re: Ratio of cement in concrete 2Oct 17, 2007 12:27 pm Long read here. But tells you lots of stuff.
http://www.concrete.net.au/pdf/concretebasics.pdf I doubt you'll want to hand mix enough concrete for a patio and path though. Box it up and order a truck for it. Barrow it in if need be. A lot easier. Re: Ratio of cement in concrete 3Oct 17, 2007 7:17 pm if you mix it your self u need 1 part cement 3 parts blue metal 1 part concrete sand but it is cheaper to get a mini mix than mix your self
and by the time you get the the end of pour if u mix ur self then the first conc. you lay would have set and you wont be able to put a finish on it Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4480 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3157 |
