We have heard that putting marbles into concrete, then cutting and polishing it back can result in a great finish.
Does anyone know where I might see some samples of this work?
Browse Forums Paving & Concreting Re: Polished contrete with glass marbles 2Jun 13, 2010 8:01 pm mentone premix has an indoor display with terazzo concrete (polished) but with out marbles....if your in Melb Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Polished contrete with glass marbles 3Jun 13, 2010 8:28 pm Another practice is to substitute some aggregate for tumbled/recycled/coloured glass Where you are coming from is where you are going to... Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39056 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12405 |
