Browse Forums Paving & Concreting 1 Jul 10, 2007 11:15 pm Hi everyone,
I have been having trouble working out how to pave around my existing fibreglass pool. I have recently removed a sunken exposed ag concrete surround and would like to pave the surround and possibly include a bullnose capping. Problem: Raised fibreglass coping or rim around the pool.. Can any of you offer advice about; A) Sticking bullnose pavers to this fibreglass surround (I've heard it can be done) B) Paving flush to the same height as the fibreglass surround (WITHOUT paving sinking at all later) C) Any other ideas that work better I believe that the previous concrete sunk because of the "void" or empty space underneath the raised fibreglass edge which caused the water run off to slosh around underneath and erode the sand away from underneath the concrete. I would HATE for this problem to reoccur after spending the time and money on a nice new paving job Please any assistance would be greatly appreciated... I would love to hear any lessons learned from others out there Thanks Wacker Re: HELP! Paving around fibreglass pool 2Oct 15, 2007 8:11 am you need a flexible rubber based tile adhesive for the pool copping
if you have had sinking before look and shaft vibrating the pool beams but make sure the pool is ful of water when you do this all of the paving i do for my clients is on a concrete slab around a pool it is advisable to pour a beam of conc after shaft vibration this stops the sinking if your pool has been in for some time you probably dont need to shaft vibrate just a plate compaction if you pave on a compacted crushed rock base and sand over time you will have the same problem but this will take from 6 mnths to 2 odd years paving around pools should always be on a conc base but if your doing it your self sand is the easiest option Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3761 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8347 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12480 |
