Browse Forums Paving & Concreting 1 Apr 28, 2010 3:02 pm Had our driveway put in about 2 weeks ago... 70m of 400x400 recon limestone pavers. Looks fantastic and we'll be using the same pavers to do the backyard. However they used brickies cement around the edges of the driveway so the pavers don't collapse. I was advised yesterday it will break down in 6 months and that they should have used concrete. Is there much of a difference? They did such a great job that they surely know what they're doing so it lasts? Cheers Re: Concrete or cement for paving edging. 2Apr 28, 2010 8:45 pm It probably is a case of what different people have learned they will also do. My 1st boss used concrete, and I also do when I pave on sand (always lay on concrete slab and mortar now). Concrete will probably be that bit stronger being a bit higher Mpa and also having aggregate in the mix tying it together. Just make sure the haunching is set into a bit of a trench below the sand level and into the base material to lock it into place. If the mortar is pretty shallow it will move back over time and the edge pavers will do the same and fall away and sink. Planned Landscape Constructions http://www.plannedlandscape.com.au Find us on facebook http://www.facebook.com/profile.php?id= ... 9907611509 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4495 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3161 |
