Browse Forums Paving & Concreting 1 Mar 27, 2010 5:39 pm Hi. I'm building a single brick garage / workshop on raft slab. Wanting a finish that is easy to keep clean and does not create dust when you sweep it. Builder friend recommends 'granolithic finish' to slab - which is an additional thin layer of concrete, richer in cement. Builder quoting on job says a smooth trowel finish to the slab would be sufficient. I am yet to investigate the cost difference. Would any concrete gurus mind giving me an opinion on this? Thanks in advance. Re: best finish for slab in proposed garage /workshop ? 2Mar 27, 2010 6:51 pm I take it the concrete has not yet been done?? IF not, then just ask the granos to give you a 'burnished' finish and not to use any water.. Where you are coming from is where you are going to... Re: best finish for slab in proposed garage /workshop ? 4May 30, 2010 4:21 am Im have my garage floor Grinded and poished using a concrete polisher ... it take a few mm off the garage floor and exposes the aggreate (spelling) ... but you end up with a cool looking floor finish that you simply apply a 2 pack clear coat sealer too. Looks great, no more dust.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We're building The Albany 330E with Casa Design & Construction via National Builders Group See how we are going here: https://forum.homeone.com.au/viewtopic.php?f=31&t=32694 Re: best finish for slab in proposed garage /workshop ? 5May 30, 2010 7:13 am Wow, love that finish TheAlbany. Is it slippery when wet. I have to be careful in my thongs now on our normal garage if they're wet. Forever look like going bum up. I love the look of polished concrete. Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8409 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9569 4 14463 |
