Browse Forums Paving & Concreting 1 Mar 15, 2010 9:20 pm Hi all, would really appreciate some advise on cleaning off set concrete or mortar from brick work appears to be left over splashing from a very untidy edge paving job. sorry but unable to provide a photo. needless to say these are a light tan pale coloured brick and it is giving my better half the irrits. Re: HELP AND ADVISE ON CLEAN CONCRETE OR MORTAR FROM BRICKWO 2Mar 15, 2010 9:29 pm We used a steel brush and a karcher (high pressure hose). Long, tedious job but it didn't damage the brickwork. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: HELP AND ADVISE ON CLEAN CONCRETE OR MORTAR FROM BRICKWO 3Mar 16, 2010 5:02 pm Mortar being reasonably sandy will come off pretty easy with a wire or stiff brush then getting a high pressure hose to it. If it is concrete or something a bit harder than mortar try a 10:1 hydrochloric acid mix and water (make sure you add acid to water no other way round), give it a bit of a scrub which will loosen it then use the high pressure. You can get the acid or other suitable cleaning products from the garden yard, Bunnings would probably sell it too Re: HELP AND ADVISE ON CLEAN CONCRETE OR MORTAR FROM BRICKWO 5Mar 17, 2010 4:02 pm goto local concrete tool supplier and get a product called liquid hammer, it disolves the fly ash in conc. cleans better than hydro. acid. will still need high pressure cleaner Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: HELP AND ADVISE ON CLEAN CONCRETE OR MORTAR FROM BRICKWO 7Jun 23, 2010 12:38 pm What kind of a pressure cleaner would you recommend? Does it have to be a heavy duty one or will a baby one do the job? Re: HELP AND ADVISE ON CLEAN CONCRETE OR MORTAR FROM BRICKWO 8Jul 14, 2010 10:30 am I reckon this stuff looks amazingly easy: http://www.cretewash.com.au I was planning to use this to clean up the old concrete around the pool. Does liquid hammer work this well? I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the… 0 1913 Recently I moved to a 30 year old house and found within few months there are small brown nests in the brick mortar and few small round holes in few places of brick… 0 22689 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17305 |
