Browse Forums Paving & Concreting Re: Fiberglass pool resurfacing 2Mar 03, 2010 7:09 pm Where you are coming from is where you are going to... Re: Fiberglass pool resurfacing 4Mar 03, 2010 7:59 pm Where you are coming from is where you are going to... Re: Fiberglass pool resurfacing 6Mar 14, 2010 10:30 pm Keen - If you want to place a coping tile, then I'd be suggesting using a polyurethane caulking compound. ... then use the same ‘glue’ to ‘joint’ control the under edge of the coping. If you want some info PM me and I will give you a few options There are no cement based products that will handle the thermal co-efficient difference between fibreglass and a rigid man-made product, so no point in trying Where you are coming from is where you are going to... Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4774 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13636 |
