Browse Forums Paving & Concreting 1 Mar 02, 2010 7:12 pm I have just bought a H+L package. My question relates to paving (with probably many more to come about other things not paver related). I was under the assumption that to lay pavers flush/next to a house, that you would take the ground down however deep it should be, 150mm?, below the weep/breather holes and the black stuff that goes under your brick walls, just above the slab (flushing?). now am I right in thinking that the pavers would be angled away from the house for dispersing water? The reson I ask is, our landscaper made the pavers too high, ie above/covering these weep holes. behind the house is paved and the pavers are only just covering them. Whereas the same paving around the side of the house is a good inch or two above the weep holes. shouldnt they be the same height all the way around? If you need anymore info or pics please let me know. http://pbckt.com/sc.OU7 - The strip Drain is essentialy flat and came after the paving. Cheers muchly Re: Noobie question about paving 2Mar 02, 2010 7:31 pm They should be just above the slab and below the weep holes. Re: Noobie question about paving 3Mar 02, 2010 7:32 pm Oh and they should drop away from the house where possible. Re: Noobie question about paving 4Mar 02, 2010 11:33 pm I think what Fu is saying is there should be 'Fall' away from the house. The slab edge should be visible for white ant inspection. If the pavers are above the top of slab edge this is wrong for many reasons see 2 ^^ Where you are coming from is where you are going to... I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12325 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5699 |
