Browse Forums Paving & Concreting 1 Feb 09, 2010 7:33 pm I desperately need someone to supply and install or just install metal wall cladding. If you know anyone please let me know asap. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4494 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12069 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11122 |
