Browse Forums Paving & Concreting 1 Feb 03, 2010 7:13 pm Hi can anyone tell me how many kilograms of cement how much sand m3 water etc to make one cubic meter 1m3 of concrete. I will be using a standard cement mixer. I am going to be constructing some reinforced concrete pillars. Thanks for any help in advance. Re: How much sand cement water to make 1m3 of strong concrete? 2Feb 17, 2010 3:45 pm .166 kg General purpose cement .333 kg washed sand .500 kg blue metal This will make approx 1 cubic meter of concrete Landscape Design & Construction http://cherub.squarespace.com/ Re: How much sand cement water to make 1m3 of strong concrete? 4Feb 17, 2010 4:39 pm cherub - that is for 1000kg of concrete - the question was for 1 cu mtr of strong concrete I'm not sure how strong, strong concrete is. Standard concrete is 20mpa, stronger is 25mpa and stronger again is 32 mpa. 1 cu mtr of concrete is 2800kg Where you are coming from is where you are going to... Re: How much sand cement water to make 1m3 of strong concrete? 5Feb 17, 2010 4:52 pm sorry for that 1 cubic meter = 1200 kg Blue metal 800 kg Sand 400 kg Cement Landscape Design & Construction http://cherub.squarespace.com/ Re: How much sand cement water to make 1m3 of strong concrete? 6Feb 17, 2010 4:56 pm ...perhaps better not try and make a formular. 1 cu mtr has about 260kg of gp cement (25mpa) Where you are coming from is where you are going to... Re: How much sand cement water to make 1m3 of strong concrete? 7Feb 17, 2010 7:18 pm Mixing 2.5 tons of concrete in a backyard mixer is crazy, it'll be long and hard slog, I should know, I've tried it once, on half of that amount, it almost broke my back and the result wasn't all that good. Most concrete producers can deliver mini-loads of concrete, starting from 1/3 of m3. It costs more, but saves a lot of hassle. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: How much sand cement water to make 1m3 of strong concrete? 8Feb 28, 2010 12:06 pm practically speaking we are talking in terms of volume rather than weight (you will buy your sand and blue metal by volume anyway). 1m3 is something like about 8 - 12 (?) builders barrow loads - not a huge amount. I believe Cherub's 2nd posting of the formula at 3:2:1 (aggregate, sand, cement) is correct. Regarding the amount of water - I suggest enough to make it a nice workable consistency. Not too stiff, not too sloppy - like whipped cream. You might make the first few loads a little on the sloppy side if it is going to be a long pour. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4456 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3125 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17529 |
