Browse Forums Paving & Concreting 1 Jan 25, 2010 12:35 pm We wanted to paint the garage floor, but DH is not happy with the floor of his shed which he painted following the advice of the guy at the paint shop. It's very slippery and dangerous and we don't want to repeat the mistake in the garage. Does anyone know how we can fix the shed floor, and what can we paint the garage floor with that will be non-slip? Thanks in advance.... Re: Painting garage floor 2Jan 25, 2010 12:51 pm A couple of questions for you and for anyone out there who knows, why paint a garage floor, and is there in fact any way of doing it that doesn't commit you to ongoing maintenance given that a garage floor would have to be a really hardwearing surface to cope with the cars? Re: Painting garage floor 3Jan 25, 2010 2:49 pm Laine We wanted to paint the garage floor, but DH is not happy with the floor of his shed which he painted following the advice of the guy at the paint shop. It's very slippery and dangerous and we don't want to repeat the mistake in the garage. Does anyone know how we can fix the shed floor, and what can we paint the garage floor with that will be non-slip? Thanks in advance.... Buy some friction enhancer ( silica fume) from the hardware and re-paint the floor... Using 'spread and sprinkle' and roller. Where you are coming from is where you are going to... Re: Painting garage floor 4Jan 25, 2010 7:28 pm Dulux used to have a specialist DIY non-slip garage floor kit - can't see it on their website anymore but try Bunnings. P1T Read about my building experience: http://secondhomebuild.blogspot.com Dale Alcock Homes - 'The Nautilus' in Bletchley Park, Southern River - WA Read about my Clipsal C-BUS Home Automation Project: https://forum.homeone.com.au/viewtopic.php?f=34&t=20854 Re: Painting garage floor 5Jan 25, 2010 8:18 pm Yep - Dulux garage floor treatment - $145 for a single car area. After 4 years - we're in! Re: Painting garage floor 6Jan 26, 2010 9:41 am Macy, yes I understand what you are saying, we just thought any spills or stains wouold be easier to remove from a sealed surface, and concrete is porous and soaks liquids up. The Dulux product seems quite expensive - will look into the friction enhancer. Thanks for the replies! Re: Painting garage floor 7Jan 26, 2010 9:45 am just in case anyone else reads this thread and sees what you said about staining and taking up liquid... There are other products to use other than paint concrete sealers, etc... that an over coat rejuvenates. Where you are coming from is where you are going to... Re: Painting garage floor 8Jan 26, 2010 11:10 am Would that be polishing Onc? The Dulux coating is no good if it is exposed to UV light. For example a second access way to the garage that is open a lot, a window that is uncovered, a door that is open a lot. I was hoping to use the Dulux on mine but no good You see in new workshops/ service centres the floors are often painted and they stand up to some serious wear pretty well. I want mine done in cream so it makes the garage lighter and spills of fluids are easy to wipe up. oils, brake fluids etc. Any ideas folks? Has to be pretty tough to light? Re: Painting garage floor 9Jan 26, 2010 11:16 am UV stabilized epoxy... how old is your garage Fu? Where you are coming from is where you are going to... Re: Painting garage floor 10Jan 26, 2010 11:44 am It's about 5 years old from memory. The floor is very clean, I look after it, but there are a few oil spots, as in maybe 10 or 15 the size of a 10cent piece. Double garage. Say, 40m2. Re: Painting garage floor 11Jan 26, 2010 11:50 am A couple of kits would do it. No cheap by any means, but it is what is in most if not all Holden service centres. Something like this: http://www.sika.com.au/cmc/Datasheets/t ... orHSau.pdf Where you are coming from is where you are going to... Re: Painting garage floor 12Feb 08, 2010 2:27 pm We painted ours using the Dulux Garage floor kit (Bunnings has it). Not slippery at all in the wet. Reason is that you first scrub the concrete with a hard bristled broom to roughen up the surface (adds traction) and then you mix the paint with a non slip mix which adds more texture and traction. The one kit does a standard double garage. You will need more if you have a big double garage (eg small workshop area etc) Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: Painting garage floor 13Feb 12, 2010 1:39 pm onc - what do you think about polyurea floor coatings like this mob? http://www.flexiconsw.com.au/citadel-floors The product above is about $28/m2 And what sort of price would be reasonable for a good solvent-based epoxy floor? (I hear the Dulux product is only water based and those are almost guaranteed to have some sort of paint lift) After 4 years - we're in! Re: Painting garage floor 14Feb 12, 2010 3:00 pm The product has been around for a long time I'd run it past them and see what they have to say Where you are coming from is where you are going to... isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17502 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16535 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5015 |
