Browse Forums Paving & Concreting 1 Jan 23, 2010 12:12 pm hi i will be doing my driveway in expossed agg soon,and i will be needing a grate for the stormwater to run into, as the driveway has a slight slope towards my garage. so im just wondering , if a plumber will be needed or will the concreter do this. also what type of price will i be looking at to get this done... cheers. Re: stormwater grate, in new driveway............. 2Jan 23, 2010 12:22 pm good luck on the grannos doing it They might though. They will need to have it how they do the levels so they'd get it in the right spot. The plumber is going to need to set it up though. Re: stormwater grate, in new driveway............. 3Jan 23, 2010 12:48 pm We are about to do two stormwater drains in front of the garage. The concrete guy said he will do it all and it is included in his quote. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: stormwater grate, in new driveway............. 4Jan 23, 2010 1:10 pm My paving guys did mine, but I already had the surface storm water pipes so they just connected my grate drain to that. Re: stormwater grate, in new driveway............. 5Jan 23, 2010 6:11 pm The drain is usually set in place by the concrete contractor, the hookup into a drainage system is left to licensed drainers. Though it really depends on who your contractors are, and what they are willing to do. Expect 300 or so for the setting of the drain by the concrete contractor, (double garage) and anywhere from 300-30,0000 for the drainage hookup by a plumber Re: stormwater grate, in new driveway............. 6Jan 23, 2010 6:13 pm ^^^ Where you are coming from is where you are going to... Had a new driveway installed with a 6 metre long 150 x 150 channel drain and have since found out it has 4cm of water sitting at the bottom below the side pipe… 0 4716 Hi All! I have engaged a plumber to re-do the stormwater drainage system on my property which is mid-70s and had blocked/cracked clay pipe drains. The works has… 0 18666 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4768 |
