Browse Forums Paving & Concreting 1 Jan 20, 2010 11:27 am hi im about to do my driveway in expossed agg, in the next 3 to 4 weeks. and just looking by eye there does not seem to be much fall, from top of garage floor to the front footpath. so my question is how much fall is enough. i dont really want to use a grate ,if i can get out of it. i realize there has to be some fall for water to get away. has anyone got any thoughts........ Re: how much fall is enough for my concrete driveway.......... 2Jan 20, 2010 11:32 am I would have thought that the greater the fall, the more need for a grate. With a gentle fall, more water cna be absorbed before it runs off. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: how much fall is enough for my concrete driveway.......... 3Jan 20, 2010 11:43 am I guess for my 3000th post it should be a concrete question Probably better you give some more stats. Like the length of the drive, width and if the road is lower than the garage. Also the soil type adjacent to the drive. The drive can be slightly convex so the flow goes to each side. Where you are coming from is where you are going to... Re: how much fall is enough for my concrete driveway.......... 4Jan 20, 2010 12:25 pm sorry onc driveway is 6 metres long 5 metres wide. top of footpath looks like its the same hight as the garage floor, ill need to get the laser level and see. as i dont want the water running back to my garage. soil is clay , rock,. so if there is say 1 inch of fall away from garage would this be enough. if it is dead level would i need to put a grate in. cheers.. Re: how much fall is enough for my concrete driveway.......... 5Jan 20, 2010 4:11 pm My puter crashed as I was posting, (lost power, we have a N00B neighbour who likes to turn off our power for laughs ) looks like you will need drainage yes. ....but I don't suggest you put in a bunch of soak wells under your driveway. Specially since you are on clay. Is any of you block lower than your house? That is a large(ish) catchment area 30 sqs flat. If you live in an area that has 1mtr of rain PA then the drive will have to deal with 30kl PA... If it goes nowhere then I suggest it will flow towards your house, which presumably is on a sand pad?? Where you are coming from is where you are going to... Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4691 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18402 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1920 |
