Browse Forums Paving & Concreting 1 Jan 13, 2010 2:05 pm I'm currently getting quotes for exposed agg for my driveway and around the house. I've had a quote that the cheapest mix is $85 per sq meter. Does this sound about right??? we need about 90 sq meters so its not going to be cheap. I'm not sure what it should cost Re: Price of exposed agg in geelong 2Jan 13, 2010 7:00 pm PieMan, We have spoken to someone today re a quote for something similar I think. I will let you know when the quote comes in what the cost is. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: Price of exposed agg in geelong 3Jan 13, 2010 7:07 pm $85 is a good price for an expossed mix, if it includes excavation then it is to cheap Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Price of exposed agg in geelong 4Jan 13, 2010 7:10 pm $85 sq mtr inclusive of GST? ...would be good to get a name for the mix if you can ...an some details like : thickness (80mm or 100mm), mesh ( reinforcing) and plastic (moisture barrier) Where you are coming from is where you are going to... Re: Price of exposed agg in geelong 5Jan 16, 2010 10:10 am onc_artisan $85 sq mtr inclusive of GST? ...would be good to get a name for the mix if you can ...an some details like : thickness (80mm or 100mm), mesh ( reinforcing) and plastic (moisture barrier) this is from the concreter "To prepare site, excavate, put down any necessary crushed rock, box up desired area and prepare. All concrete shall be 25mpa, shall be a minimum of 100mm thick and shall be reinforced with F62 mesh." 85p/sm Re: Price of exposed agg in geelong 6Jan 16, 2010 10:30 am ...and the agg mix is? (colour) Where you are coming from is where you are going to... Re: Price of exposed agg in geelong 8Oct 15, 2011 6:58 pm Any luck? We are building right near you and looking into driveways.. Re: Price of exposed agg in geelong 9Nov 03, 2011 4:49 pm Updating this thread. Answer is about $100 per square metre. Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 11089 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10574 After some ideas on making our patio kid friendly . Currently we have exposed aggregate. The patio faces west and is always in sun even though it has a shade directly… 0 4516 |
