Browse Forums Paving & Concreting 1 Jan 11, 2010 12:03 pm Hi all What should we expect to pay to have large cement slabs removed in Perth? It's under a 6X9 shed and the driveway up to a shed ~8X6. Looks like they could have been hand poured as they are in sections. The shed is also there and needs to be removed. Any recommendation/suggestions of companies to remove shed and cement slabs appreciated. cheers D Re: Removing cement slabs 2Jan 11, 2010 12:25 pm Hi drs10, I've had similar 'undershed' cement pieces removed recently, I had 3 pieces of 3x6m removed for $1550, although they did chop down some trees for me at the same time, so it could have costed less. I found the tradesperson from: http://www.servicecentral.com.au/ Try them out, they will allocate suitable tradespeople that works in your area to call you and quote. Make sure you tell the tradespeople you can pay cash cheers my suspicion - some builders, they do usually make 'odd' settings in their site plan / pricing as their standards - being hopeful that first - the initial price is… 9 2444 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4471 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3146 |
