I've had my portico paved with honed sandstone tiles. Unfortunately some of the have surface scratches, I'd like to remove before sealing the stone. What's the best way ??
Chris
Browse Forums Paving & Concreting 1 Dec 29, 2009 11:05 am I've had my portico paved with honed sandstone tiles. Unfortunately some of the have surface scratches, I'd like to remove before sealing the stone. What's the best way ?? Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Removing scratches on sandstone ?? 2Jan 04, 2010 4:58 pm get in contact with a local dimaond tool supplier and get a fine honing disc (wet) for a 4 1/2 inch grinder, the grinder has to be variable speed, use the speed as per disc supplier instructions, kennards etc may hire a stone polisher etc Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Removing scratches on sandstone ?? 3Jan 04, 2010 6:58 pm Try the sealer you have an off cut of, it might hide it. ( the scratches) Otherwise kennards but get a bigger than 4 1/2" (7" and marble diamond grinding pad) you will end up with less lateral movement and get a better job. Be careful the finish on the original is probably less fine than the pads will give you. (400grit or so) Where you are coming from is where you are going to... Re: Removing scratches on sandstone ?? 4Jan 05, 2010 9:34 pm Thaks Davinci and Onc, I've decided to try a sealer first, before resorting to a more dractic action, and it worked. Mostly, 99% of the scratches dissapeared, I can live with the remaining 1%. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Removing scratches on sandstone ?? 5Jan 05, 2010 9:36 pm That makes life easier Where you are coming from is where you are going to... Re: Removing scratches on sandstone ?? 6Jan 06, 2010 1:22 am Chris, what sort of sealer are you thinking of using? (or is it too late)? Don't fall for the common misconception that sealers are all pretty much alike! Got any pics of the sandstone? Ash. I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12389 6 11144 The best advice is for you to get a competent building consultant to guide you through your build 7 4677 |
