Browse Forums Paving & Concreting 1 Dec 14, 2009 7:45 pm I have my slab done but it's not sealed yet. I am going to put timber floor later on (more likely 3 to 6 months) & going to use the slab in the mean time but it's so dusty & i dont know what I should coat it with? should i use sealant or just paint? can i buy something in 15L or 20L & roll it? thanks for any tips ttn Re: Help please. How to seal a concrete slab? 2Dec 14, 2009 9:07 pm If you are going to put down a floor covering that requires a glue or adhesive to stick the covering to the floor you should not put any coatings down on the surface first. This rules out almost all floor coverings apart from carpet and floating timber/bamboo. If you do you will need to remove it before you can install the new floor covering down the track. It can be costly and a little dirty to have the surface diamond ground to remove coatings and sealers. Cheers Slugger Re: Help please. How to seal a concrete slab? 3Dec 15, 2009 5:54 am slugger95 If you are going to put down a floor covering that requires a glue or adhesive to stick the covering to the floor you should not put any coatings down on the surface first. This rules out almost all floor coverings apart from carpet and floating timber/bamboo. If you do you will need to remove it before you can install the new floor covering down the track. It can be costly and a little dirty to have the surface diamond ground to remove coatings and sealers. Cheers Slugger i did not know that at all so thanks Slugger. i'm going to put batten on the concrete & then solid timber Re: Help please. How to seal a concrete slab? 4Dec 15, 2009 1:58 pm Yo slugger, Whilst I agree in part, a sealer binder as-aposed-to paint would be used as a primer before gluing. Also with the diamond grinding we (and I though every professional outfit would be the same) ... use vacuum extraction so there is NO dust, or at least very minimal. But since batten will be used, This comment of mine goes no where. Just thought I should clear up the dirty comment. Cost is relative, sanding a concrete floor at a cost of about $8 sq mtr. ttn slugger95 If you are going to put down a floor covering that requires a glue or adhesive to stick the covering to the floor you should not put any coatings down on the surface first. This rules out almost all floor coverings apart from carpet and floating timber/bamboo. If you do you will need to remove it before you can install the new floor covering down the track. It can be costly and a little dirty to have the surface diamond ground to remove coatings and sealers. Cheers Slugger i did not know that at all so thanks Slugger. i'm going to put batten on the concrete & then solid timber Where you are coming from is where you are going to... Re: Help please. How to seal a concrete slab? 5Dec 16, 2009 4:25 pm google basf there in clayton area from memory and get a few tins of epoxy or get a few tins of clear concrete sealer about $140 for 20 ltr from concrete supplier like slatecrete etc both sealers are toxic so in doors wear breathing apparatus Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Help please. How to seal a concrete slab? 6Dec 16, 2009 7:26 pm ^^+1 Where you are coming from is where you are going to... Re: Help please. How to seal a concrete slab? 7Dec 20, 2009 8:05 pm davinci google basf there in clayton area from memory and get a few tins of epoxy or get a few tins of clear concrete sealer about $140 for 20 ltr from concrete supplier like slatecrete etc both sealers are toxic so in doors wear breathing apparatus thanks Re: Help please. How to seal a concrete slab? 8Dec 20, 2009 9:17 pm ttn - is it for indoors? If so there are nil VOC sealers. onc ttn davinci google basf there in clayton area from memory and get a few tins of epoxy or get a few tins of clear concrete sealer about $140 for 20 ltr from concrete supplier like slatecrete etc both sealers are toxic so in doors wear breathing apparatus thanks Where you are coming from is where you are going to... Re: Help please. How to seal a concrete slab? 9Dec 20, 2009 9:41 pm Can i add as soon as you hit the floor with a diamond grind you are going to open it up and release all the moisture in the floor that is still active in Hydration Id be using a mositure barrier if you do grind otherwise all hell will break loose with Vapour transmission even in batton floors Also dont forget to climatise your flooring whatever you decide Direct stick wood i hate/ batton is getting better Best product for batton would be product called Moisture Fix 2, its a broom applied mositure barrier with built in sealer and anti-microbial which helps keep nasty stuff at bay Re: Help please. How to seal a concrete slab? 11Dec 21, 2009 10:00 am getnewlookjason Can i add as soon as you hit the floor with a diamond grind you are going to open it up and release all the moisture in the floor that is still active in Hydration Id be using a mositure barrier if you do grind otherwise all hell will break loose with Vapour transmission even in batton floors Also dont forget to climatise your flooring whatever you decide Direct stick wood i hate/ batton is getting better Best product for batton would be product called Moisture Fix 2, its a broom applied mositure barrier with built in sealer and anti-microbial which helps keep nasty stuff at bay thanks, will check how about if I use plywood instead of batten? is Moisture Fix 2 ok too? Re: Help please. How to seal a concrete slab? 12Dec 21, 2009 1:17 pm Yeah Mositure fix is suitable, forgot to mention its totally eco friendly Just remember with direct stick you need total adhesive coverage on your wood, if you do little squiggles of glue that leaves paths for vapour transmission otherwise POP Regards Re: Help please. How to seal a concrete slab? 14Dec 22, 2009 9:10 pm $32 ltr Where you are coming from is where you are going to... Re: Help please. How to seal a concrete slab? 15Dec 22, 2009 10:00 pm Unlike hydropoxy its not cheap Soft broom applied and you will do 50 sqm in 15 mins Did you explain what you were doing to Prot3ct Cr3t3 > wondering why they sold you moisture fix 1 instead of 2 Even though mositure fix 1 helps tie up the moisture in your slab its the pressure of transmission through the slab that makes wooden floors esp direct stick POP, hence vapor will still come through but at a vr low pressure If you have made sure you achieve total adhesion on your timber and make sure that timber has climatised The reason why i stated using MF2 is that i has a built in sealer which stops any vapor transmission from occuring BTW the Cartoon guy on the Bucket is actually Me great joke when i was there crooked smile and all edited by a mod. Mentioning a company name is the same as advertising, this is a building forum not the gazette. Please understand if anyone wants to advertise their product, their company name, then costs are involved. It is quite another thing to PM a product or company recommendation. I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5200 4 14301 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12783 |
