Browse Forums Paving & Concreting 1 Sep 27, 2009 1:24 pm Hi folks, can anyone tell me if there is anything special required for concreting an area that will have large format 600x600 tiles laid on top after? We have a 13 sqm alfresco area that I need to get concreted in a few months and we have already selected the "outdoor" version of our indoor tiles. I do remember reading somewhere that large format tiles require a very flat surface and wondered if this meant I needed some type of special concrete put down on the alfresco area? Any help, advice and experienced appreciated. Emptyvessel Re: Special concreting or preparation for large tiles? 2Sep 29, 2009 4:40 pm The concrete should be min 25 MPa with appropriate reo for your site. It should be trowel finish not rough screed or at a minimum bull float and fresno trowel, the fresno should be run until no major visiable trowel marks can be seen with required fall. the concrete will need to cure as per adhesive manufacturors instructions and most probably acid etched to help adhesive key to conc. to avoid acid etch when the final trowel finish is obtained the concretor can apply a broom finish this will help also with adhesive keying to conc. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8266 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4474 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9177 |
