Browse Forums Paving & Concreting Re: Crack in Driveway 2Sep 01, 2009 4:36 pm if he is concerned about his reputation, he will come and fix it speak to him , see if he is ready to come back and repair it , if he gives you the run around , put his name on the forum and warn others not to go him, Re: Crack in Driveway 3Sep 01, 2009 7:39 pm Concrete can and does crack, the contractor should install appropriate base (rock) correct size reo and control joints in required locations, appropriate MPa strength, and correct thickness, if there is a need for piers in a cut and fill site then they should be installed. No contractor, concrete supplier will guarantee against cracking. If they have done all prep and installation as required for your circumstance then they have no legal or otherwise obligation to repair the crack unless it is as stated a structural defect caused by improper installation. As far as colour changes, blotchy etc then that is a problem and the concretor should rectify. Also if the finish and drainage/fall is not as it should be then the concretor should rectify. Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9316 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 |
