Browse Forums Paving & Concreting 1 Aug 23, 2009 11:07 pm Our backyard is probably just over 100m2 and we are considering paving it for the kids to play. As it is, the ground is quite uneven, so would need to flatten it. What are some of the cheaper options of paving it? What sort of pricing should we expect? Is this a job for the handyman or should we get a paving professional? Just figuring that handyman might be cheaper. Thanks in advance. It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9356 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25261 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 14228 |
