Browse Forums Paving & Concreting 1 Aug 18, 2009 2:07 pm Hi folks, I am in the process of getting quotes for my concreting - I have about 60 square meters. I have tried to keep the quotation process as fair as possible by locking down the parameters/variables for the job. I ahve specified the mesh (F-62), thickness (100mm/4inch) , area (doh !) , grade (N25) and the type of concrete ( plain). Quotes include bobcat hire (if the quoter does not have his/her own bobcat) and GST All concreters are laying down crushed rock before spreading the concrete. Are there any other things I have'nt locked down? Suburbia is where the developer bulldozes out the trees, then names the streets after them. Re: CONCRETING: what to ask for 2Aug 18, 2009 5:16 pm drainage if need Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: CONCRETING: what to ask for 3Aug 18, 2009 9:45 pm Concreting where and for what? if its a driveway that's one thing and what about the soil it is on? try http://www.concrete.net.au/publications ... %20Web.pdf http://www.concrete.net.au/publications ... gory=Guide There are two pages on teh second reference and there are some good publications which will give you some great understanding of concrete. http://www.concrete.net.au/publications ... ta%20Sheet The data sheets are brilliant Dan C It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8265 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4474 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9176 |
