Browse Forums Paving & Concreting 1 Aug 11, 2009 11:46 am Hi, just starting out on this house building scary journey. Having a concrete slab, and only just heard about concrete polished floors, including the terazzo look. Just seen the acid wash problems here and thought . Any tips very welcome! We are in West Gippsland, recommendations taken on board too. Thanks. Re: concrete floor advice 2Aug 11, 2009 12:04 pm A few questions: What are you looking for in your floor? What budget do you have for flooring finishes?(Sq mtr) What stage are you at in the building/design process? onc_artisan Where you are coming from is where you are going to... Re: concrete floor advice 3Aug 11, 2009 12:27 pm OK. We have floor plans ( Harkaway Home , Rutherglen). Only just settled on property so in the very preliminary stages. Will consider different pricings if it means don't have to use other floor coverings. Thought of having carpet in bedrooms, hard floors most other areas. Budget...at the moment, have a quote which allows about $85m2 for the slab. ( Adding ...class m raft slab, 100ml thick, double dutch to me!) Could look at this two ways. One as a temporary measure to have a reasonable floor until we can afford to do an alternative ( the acrylic surface??), or secondly, pay a bit more I guess and to the terazzo type thing? ( More like a cut and polish several times over). Just done some initial research. Some say to watch out for cracks. I have no idea. Thanks. Re: concrete floor advice 4Aug 11, 2009 5:15 pm i cannot really see the terrazzo fitting in with the style of harkaway homes, they are more federation, colonial from what i have seen in there display in officer Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: concrete floor advice 6Aug 12, 2009 6:57 am Hey comic, I was on a few other things, so time poor soz for that Hey yes you could have a coloured aggregate mix added to the slab, and just hone the surface, to give you a smooth easy clean floor... and then when more funds are available you could polish it... If you wanted that is..finding a few people like just the grey (black oxide 50%) more than fully ground and polished concrete these days. just a thought onc_artisan Where you are coming from is where you are going to... Re: concrete floor advice 7Aug 12, 2009 8:17 am Thanks for that artisan. Have you heard of any problems with cracking? Adding....(Put this in another post, I'm all over the place. ) Found this. In the states but it explains the more expensive process, rather than the sealant. Also used here by Pro Grind. Interesting. You can make it look like what you want. pros...hardwaring, low maintenace, light reflective. cons...needs to be insulated underneath. Talking to myself... http://www.buildinggreen.com/auth/article.cfm/ID/3252/ Report this post CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16561 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
